Ir para conteúdo
Search the forums
Theme Settings
Foto
Trocando o sensor de temperatura de água
47 respostas neste tópico
#1 OFFLINE   Carlinho
Carlinho
  • Membros Inativos
  • 1.472 posts
  • Idade: 35
  • Cidade/UFBrasília - DF
Postado 18 maio 2010 - 8:56
Edit: I added this to my site with other DIYs which can be found here:
http://www.anthonyda.../tempsender.htm
The following fault code was causing my CEL to come on. I would clear the code using my VAG-COM but it would come back within a short period of time.
17704 – Error in Mapped Cooling System (usually temp sensor or thermostat)
P1296 – 35-00 - -
I went to the dealer and purchased the updated temperature sender (green-top) for about $13 with a new O-ring ($2)
Imagem Postada
OLD -Temperature Sender (Black)
Part#: J78-919-501C
NEW/Updated - Temperature Sender (Green)
Part#: 059-919-501A
O-Ring
Part#: N90316802
Retaining Clip
Part#: 032-121-142
Tools Needed:
Flat-head screwdriver
Before beginning this procedure, ensure you allow your engine to completely cool down. The system is pressured and if you remove your temperature sender while it is still hot, coolant will spray out and potentially cause severe burns.
WARNING: This procedure was performed on my 2001 Volkswagen Jetta 1.8T. I cannot gaurantee this will work on your vehicle. Work at your own risk. It took me about 5-10 minutes to complete this.
Step#1: Remove the upper and lower engine covers to allow easy access of the temperature sender.
Step #2: Remove the retaining clip that secures the temperature sender in place. Slide the pick into the small portion of the clip that can be seen. (between the plastic housing and edge of retaining clip). Pull the clip straight out with minimal force.
Imagem Postada
Step#3: With the clip removed pull the temperature sender out. Unplug the 4-pin harness.
Imagem Postada
Imagem Postada
Step#4: Plug the new temperature sender (green) into the 4-pin harness.
Step#5: Insert the new sender and be sure to press it in firmly.
http://www.anthonyda...r/tpsinstallJPG
Step#6: Slide the retaining clip and ensure it is securely seated.
Step#7: Install the upper and lower engine covers.
That’s it! If you have any questions feel free to contact me via EMAIL, PM, or IM.
Fonte
  • williamwd e Mfabricanti curtiram isso
A3 1.8T 150 2P Prata
160WHP
Imagem Postada
Tem alguma dúvida? Crie um tópico próprio e explique nos mínimos detalhes, para que facilite em como ajudá-lo.
#2 OFFLINE   Rodrigom
Rodrigom
    Aro 14
  • Membros Inativos
  • 38 posts
Postado 18 maio 2010 - 9:31
Muito bom Carlinho, belo tuto.
#3 OFFLINE   A3Branco
A3Branco
    A3 Maníaco
  • Membros Inativos
  • 745 posts
  • Idade: 44
  • Cidade/UFMacapá-Ap
  • ModeloCarros
Postado 18 maio 2010 - 12:35
valeuzão cara
to indo comprar o meu agora.. e a sonda lambda tbm
afinal, o meu a3zão é original ate de peças...
o dono anterior nunca trocou nada mano!
abcs
Marcão
A3 Branco | 1.8
Macapá|Amapá|Brasil
Imagem Postada
#4 OFFLINE   Jordaum
Jordaum
    Aro 99
  • Moderadores
  • 2.252 posts
  • Cidade/UFBH/MG
  • ModeloA3
  • Motor1.8T 150cv
  • Ano06
  • Cor:Preto
Postado 18 maio 2010 - 13:58
Itacua (Ribeirao Preto-SP) 0xx16,2102-0444 Qnt:93 Valor:79,00 SENSOR TERMIC
[]s,
Jordão
#5 OFFLINE   A3Branco
A3Branco
    A3 Maníaco
  • Membros Inativos
  • 745 posts
  • Idade: 44
  • ModeloCarros
Postado 18 maio 2010 - 14:01
valeu,,, vou verificar o frete
abcs
Marcão
A3 Branco | 1.8
Macapá|Amapá|Brasil
Imagem Postada
#6 OFFLINE   andrecorrea
andrecorrea
    Aro 14
  • Membros Inativos
  • 29 posts
  • Idade: 40
  • Cidade/UFSta Cruz do Sul/RS
Postado 10 agosto 2010 - 20:50
desenterrando o topico....fiz a busca e não encontrei nada referente.
-gostaria de saber se alguem sabe onde consigo o cabo(chicote) desse sensor...
acho que meu problema é o tal cabo. comprei outro sensor e o problema(temperatura oscilando de zero a noventa graus) persiste...
desde já...
valeu pessoal.
A3 1.6 2001
#7 OFFLINE   marcosmr
marcosmr
    Aro 16
  • Membros Inativos
  • 131 posts
  • Idade: 34
  • Cidade/UFSão Paulo - SP
Postado 29 setembro 2010 - 8:43
srs,
este e o sensor que fica dando o alerta no VAG-COM Engine Coolant Temperature Circuit High Imput?
Apenas mais um, neste bando de loucos!!
Imagem Postada
#8 OFFLINE   Northon
Northon
    Aro 20
  • Membros VIP
  • 1.112 posts
  • Idade: 31
  • Cidade/UFSanto Ângelo/RS
  • ModeloAudi A3
  • Motor1.8t 150cv AGU
  • Ano2002
  • Cor:Prata
Postado 29 setembro 2010 - 9:21
e cuidado para nao quebrarem a trava de plastico que prende o sensor, referido no passo 3
Powered @ A3'02 1.8t 150cv AGU Automático
#9 OFFLINE   marcosmr
marcosmr
    Aro 16
  • Membros Inativos
  • 131 posts
  • Idade: 34
Postado 29 setembro 2010 - 11:24
percebi q deve ser bem sensivel... e a msg que coloquei que está aparecendo no meu VAG-COM é sobre este sensor? abraço
Imagem Postada
#10 OFFLINE   Carlinho
Carlinho
  • Membros Inativos
  • 1.472 posts
  • Idade: 35
Postado 29 setembro 2010 - 11:26
qual o código do erro que tá gerando?
160WHP
Imagem Postada
#11 OFFLINE   marcosmr
marcosmr
    Aro 16
  • Membros Inativos
  • 131 posts
  • Idade: 34
Postado 29 setembro 2010 - 11:44
16502 (P0118)
obrigado
Imagem Postada
#12 OFFLINE   marcosmr
marcosmr
    Aro 16
  • Membros Inativos
  • 131 posts
  • Idade: 34
Postado 01 outubro 2010 - 7:57
Deve ser isto mesmo carlinhos.. pelo que andei vendo na net - Pedi o meu pela ECS junto com as bobinas que queimaram, agora é esperar chegar.
abraço.
Imagem Postada
#13 OFFLINE   phabran
phabran
    Aro 19
  • Membros
  • 772 posts
Postado 17 outubro 2010 - 22:09
Uma dúvida: a leitura de temperatura tanto do painel quanto do climatronic vem desse sensor? Convém, pelo valor dele, trocá-lo e se não resolver o problema de temperatura baixa, trocar a termostática?
#14 OFFLINE   glauber
glauber
    Aro 17
  • Membros Inativos
  • 305 posts
  • Idade: 30
  • Cidade/UFMedianeira - PR
Postado 24 dezembro 2010 - 8:45
Desculpe a ignorancia, mas a troca deste sensor é somente para ele mostrar relamente o quanto esquenta o motor, ou ele influencia no funcionamento do carro?
Audi A3 1.8T 150CV Aut. 2001 4P Completo - Teto Solar / Xenon 8.000K / Rodas 17"
#15 OFFLINE   lexupdate
lexupdate
    Aro 16
  • Membros VIP
  • 125 posts
  • Idade: 38
  • Cidade/UFCuritiba/PR
  • ModeloA3
  • Motor1.8T 180cv Tiptronic
  • Ano2005
  • Cor:Preto
Postado 24 dezembro 2010 - 19:49
Também sou ignorante, mas imagino que deve ser um sistema de malha fechada. Se esse sensor não influencia, imagino que deva existir um outro sensor pra dar essa informação.
#16 OFFLINE   glauber
glauber
    Aro 17
  • Membros Inativos
  • 305 posts
  • Idade: 30
Postado 27 dezembro 2010 - 9:37
Alguém pode me dizer?? Pq o meu vai de 0 a 90ºC mto rapido e estabiliza nos 90...mas eu noto que ele esquenta mto mto!
#17 OFFLINE   giovani
giovani
    Aro 13
  • Membros Inativos
  • 1 posts
Postado 06 outubro 2011 - 10:59
alguem sabe onde ta o sensor de temperatura de agua do audi a3t cara quero trocalo mas nao to afim de leva na oficina em outros carros e bem facil a troca. mas nesse nao to achando onde ta.
#18 OFFLINE   xerminada
xerminada
    Aro 16
  • Membros VIP
  • 208 posts
  • Cidade/UFRio de Janeiro
  • ModeloA3
  • Motor1.8T 150cv + remap
  • Ano2004
  • Cor:Prata
Postado 06 outubro 2011 - 12:17
Fica do lado direito do motor (olhando de frente), em baixo daquela proteção de plástico em formato de L, tem um chicote com uma tomada ligando nele...
Em alguns é fácil de identificar pela cor, verde, em outros é preta...
#19 OFFLINE   Jordaum
Jordaum
    Aro 99
  • Moderadores
  • 2.252 posts
  • Cidade/UFBH/MG
  • ModeloA3
  • Motor1.8T 150cv
  • Ano06
  • Cor:Preto
Postado 06 outubro 2011 - 19:56
O sensor faz a mediçao para a centralina e para o painel de instrumentos (por isso tem 4 fios).
Retirado do AudiPT:
Esta mudança é muito simples mesmo... demora-se uns 10 minutos no maximo..
Material necessario:
- sensor da temperatura - ref. 059 919 501A
- Orringue - + N 903 168 02
- Liquido G12
- Alicate
1 - Com o motor a frio (devido ao liquido que sair nao estar quente) com o alicate basta puxar o Freio (na imagem o numero 14).
2 - Desengatar a ficha
3 - Puxar o sensor (na figura o n. 10) para fora (cuidado que sai um bocado de Liquido do circuito)
4 - Colocar como nas fotos o Orringue ( na figura n. 15) no sensor e unta-lo com vaselina para entrar melhor (lololo parece um filme porno mas é verdade, ajuda e muito..)
5 - Depois de estar no sitio ligar a ficha
6 - Voltar a colocar o Freio
7- Encher o reservatorio com G12 e deixar o ar sair ate o circuito estar fechado (podem ligar o aquecimento no maximo para a agua circular pelo circuito todo)
8 - Arrumar o alicate .. lolololo
Aqui ficam algumas imagens do dito sensor...
Nota: Eu troquei o orringue tambem, pois nao era bem o sensor que me preocupava, mas sim que perdia agua pelo orringue... (ja tinha mudado uma vez o sensor e nao o orringue). Assim fica um trabalho seguro.
Espero que tenha ajudado a muita gente que pensa que é um risco mudar este sensor
Imagem Postada
Imagem Postada
Imagem Postada
Imagem Postada
Mais fotos, obs: Esse motor sujo NÃO é meu!
Imagem Postada
Imagem Postada
Imagem Postada
Imagem Postada
[]s,
[]s,
Jordão
#20 OFFLINE   gabrielm
    Aro 21
  • Membros Inativos
  • 4.279 posts
  • Idade: 35
  • Cidade/UFTramandaí/RS - meu escritório é na praia
  • Modelo80s Avant
  • Motor2.6 V6 - manual
  • Ano1995
  • Cor:branca
Postado 11 outubro 2011 - 17:28
o sensor do climatronic fica naqueles rachaduras que tem um pouco acima dele...
357234357audi.gifB4 1995 80s Avant 2.6 V6 (ABC/CPE) - Casablancaweiss -> http://www.a3clube.c...95/#entry136265
357234357audi.gif8L 2005 A3 1.8T (AUQ/09A) - Black ->  http://www.a3clube.c...-carbono-pag-6/
Welcome Guest!
